Gjac
Oct 21, 2016Explorer III
"When I say flat, I mean it registered no voltage at all on a digital read out." Was the digital read out from a meter inside the MH or from a volt meter on the posts of the battery itself? If from the inside you may have corroded connections going to the meter which may also be the reason the batteries won't charge properly. If at the battery posts as others have said the battery is bad.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 27, 2026
