pianotuna
Oct 21, 2016Nomad III
Hi,
That is why the plates do not extend to the bottom of the jars. Eventually that space becomes full of detritus. At that point a cell may short out.
The negative plate sulphates. In a healthy battery that material is returned to the electrolyte when charging is completed. The positive plate erodes and that material ends up in the bottom of the battery.
Dendrites may grow between the plates and short them out.
Sam Spade wrote:
If you do manage to "knock the accumulated sulphate off the plates", it likely will short out a cell or two because of the accumulation in the bottom and change the battery's condition from "low capacity" to totally useless because of low voltage.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 27, 2026
