BobsYourUncle's avatar
Mar 02, 2014
Darn, lost my fridge in this cold weather
Well dangit anyways.
My fridge went south. I noticed the freezer wasn't quite there yesterday. It has been over minus 30C and a wind chill into the minus 40'sC. I have a light bulb going in the compartment, but guess I should have blocked the louvers as well, but didn't.
Inside the rig I have a heater aimed inside the compartment under the fridge to try and warm things up but I guess it isn't enough.
Pulled the cover off the outside and there is a flame in the burner, but all my hand tools are on the job and I need a #1 Phillips to pull the screw out so I can see how big the flame is. Don't have one handy here. Don't think there is enough flame.
Put my hand on the flue, it's warm but I don't think warm enough.
Something is askew here. Perhaps gas flow is restricted, I don't know. Lost my propane flow to the furnace in the night last night. Got up and switched tanks and it came on again. I have a heating pad on the tanks and dummy me forgot to switch off the Auto Off feature. Did that this morning and furnace is ok now.
Tried switching fridge to 110 this evening. Finally blew the breaker on my shore power feed. The circuit I have has been good but I guess with a 1500W heater, a heat tape on my dump pipes, the heating pad on the tanks, light bulb in the fridge compartment, that the heating element for the fridge is the straw that broke the camels back.
I've done pretty good actually with all that stuff loaded on one single breaker.
I went in and reset it, knocked the heater back to 750W and turned the fridge to 110 again.
Waiting game now to see if it comes back or not. It will be a while before I can tell if it is freezing again. Going to head out and block the louvers to see if that helps.
Something appears to be making the burner flame too small I think, therefore not enough cooling.
Meanwhile I have a big mess to clean up. Gotta empty my freezer into the garbage and likely half my fridge contents. There is liquid from ziplocs of chili all over the place. A few chicken breasts are still partly frozen so I can likely salvage them if I cook them right away.
My grey tank is full and coming up into the tub. Black tank getting there. Looked down the hole and it is a solid block of ice nearly up to the neck.
Nearly at the limit here guys! But I keep going. I'm determined to make it through this arctic freezup here. It is cold, really biting darned cold!
Should have just put all my food outside! It would be frozen solid!!
I know some of you have more experience with fridges than me.
Any thoughts?
  • A quick trip to PA tomorrow should remedy the tool problem. One stop shopping.
    On the bright side......at least the garlic didnt freeze!
  • BobsYourUncle wrote:
    SWD wrote:
    Abandon ship! Don the lifejackets.....man the lifeboats!
    You need to check that flame and see if cleaning out the orifice will help. Thats all I can think of. sorry.
    Ship is stuck in the ice,
    Lifejackets are all frozen together,
    Lifeboats are icelocked in their place!!
    :B
    Trying to find something here to pull the screw out to check the flame better. It's there, just don't know how high it is.
    Guess I better put a small toolbox together for the TT. I never bothered because I always have a truck full of tools with me.
    Well then you are hooped!
  • Hi Bob,
    Sorry to hear of the latest Bob zero, cold weather two game.
    On the bright side--you had a 2nd propane bottle to make the switch!
    Fridge on electric draws 325 watts. It will take at least six hours for it to cycle like as not. Leave the bottom louver open.
    I hate heating devices that "help" by doing auto shut off.
    For the chicken--stop and get some swiss chalet sauce and fries! It makes a great meal with home cooked chicken.
    :B
  • Abandon ship! Don the lifejackets.....man the lifeboats!
