Well now that every one is through guessing, here is what's happening with your alternator light.
The alt light gets a + voltage from the dash when the key is turned on. The light sees a - voltage on the other lead from the alternator when the engine is NOT running and the alternator is NOT producing. When the engine is running and the alternator is producing, the light on the dash sees a positive voltage on both leads and the light is off.
Now when you solar panels gets the line voltage above 14.6, the alternator regulator shuts the alternator down and the dash light sees a - voltage on the lead to the alternator and turns on.
Nothing wrong with you MH charging system.. The light is doing what it should.
Richard
