Gdetrailer
May 28, 2015Explorer III
Rake wrote:
Thank you. Again, please tell me where to LOOK to determine the year the chassis was built.
Typically the you can determine the build date from the Ford OEM VIN number but keep in mind Ford is supplying what is known as a "incomplete" chassis. I am not sure if the Ford VIN is still in force or if the coach builder makes a new VIN..
If you have a Ford VIN, the VIN plate should be on the drivers side dash near the bottom of the windshield.
You can run the VIN through a decoder and be able to get the date..
Here is one decoder you can try..
FORD VIN DECODER
Here is another..
HERE
Here is a link for more info on VIN DECODING
HOW TO DECODE VIN
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
