opaquejacob's avatar
opaquejacob
DC Circuit MON & GL versus GH on thermostat
Hello,
My name is Jacob. I am new to RVing. Just got a 2022 Palomino/Forest River Puma 289BHS.
I'm planning on doing some electrical upgrade and smart home installs. A couple of things are confusing me though:
1) A DC branch circuit is labeled "MON" (see picture) and I'm having no luck figuring out what that is for. It has a 15amp fuse on it, which is a decent sized circuit for an RV. Any idea what it is?
2) The thermostat has 6 wires, and I can identify 5 of them. But either GL or GH controls the propane furnace. The RV has two tanks. So is GL one side and GH the other? Or is there a different heating accessory (like a heat pump) on here? To install a smart thermostat, I need to what they are. Any idea?
Thanks in advance,
Jacob
  • 2112's avatar
    2112
    Explorer II
    Glad to help
    As wa8yxm noted, MON most likely powers the panel used to check the tank levels as well.
  • 2112 wrote:
    Welcome Jacob
    1) MON should be for the propane detector located low on the end of your galley counter cabinet
    2) GL and GH are for the AC only. Neither should have any affect on the furnace
    Thank you! You were right on both accounts. Much appreciated.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I was guessing the monitor panel
    Suggestion.. Pull fuse. See what no longer works.. Replace fuse. See if it now works.
  • 2112's avatar
    2112
    Explorer II
    Welcome Jacob
  • Figured out the thermostat from this site: https://rvshare.com/blog/ultimate-guide-to-rv-thermostats/
    GL and GH is dual fan speeds. Low and high respectively.
