pianotuna wrote:
Better to do a solenoid than a diode. Why? because a diode introduces voltage drop--about 0.7 iirc.
The device you ordered has a sense wire so it will only be active when the truck is running. If that is so, then there is no need for a diode or a solenoid.
Schottky diodes do not drop .7V..
They do drop some voltage but they typically have about .3V-.4V drop unlike Silicone diodes which typically drop .6V-.7V.
However, consider this, adding a diode in front of a DC-DC converter, that small .3V-.4V drop no longer is of any issue since the DC-DC converter will boost the voltage, overcoming any voltage loss on the input side.
The only downside with DC to DC conversion is the input current will go up some to compensate for the voltage loss..
Although personally since OP has a GM, they really NEED to add a relay to the charge line so the charge line is ONLY active with the ignition on.. A $2.00 40A "Bosch style" cube relay is all it takes. A relay in the charge line eliminates the possibility of accidentally discharging the vehicle battery when the vehicle ignition is off.. Shame on GM for being such cheapskates (a TWO DOLLAR RELAY FOR GOODNESS SAKES), Ford and Ram are way ahead of GM for this feature.
