SolanaJohn wrote:
SolanaJohn wrote:
Controller panel shows 12.7V
Turn on lights sequentially until all lights fail.
Turn off all light switches. Switch on lights (none light).
Return all light switches to off position.
Across battery 12.8V
Battery - to fuse + : 12.8V
Thanks, I did this already
Not really.
When you reach the point where the lights fail, STOP....and do not move any switches or change anything else while you check for where there IS voltage and where there is NONE.
You MUST LEAVE everything in exactly the same situation as the moment it failed.
