seabeeson's avatar
seabeeson
dc power
I cannot switch on the dc from the batteries. Nothing works. I have full power (ac & dc) when plugged to shore. Is anyone familiar with this problem?
  • Oasisbob wrote:
    Put a volt meter on your battery to confirm it is not low or dead first thing. Check fuses if no disconnect switch. Let us know
    X-2
  • Put a volt meter on your battery to confirm it is not low or dead first thing. Check fuses if no disconnect switch. Let us know
  • Is there a battery disconnect switch ? Is it ON ?
    Are the battery cables tight ?
    Is there a main discharge fuse for the batteries ??
    You REALLY need a meter; they can be had for about $10.
  • Let us know what type, model rv you have. Might give us a better idea of what the problem could be. If a dp, this problem is usually due to the disconnect switch being turned off.
    Ron
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
