I have a 2006 Forest River Sandpiper that I've owned from New. Dealing with a slow slide out motor, and pulled the belly down to get at the motor to check electrical connections. Checked voltage at ...
I doubt the wire itself is causing the 2v to 5v drop. Keep poking around and I think you will find another bad connection. Check for auto-reset beakers in the line.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
