I have a 2006 Forest River Sandpiper that I've owned from New. Dealing with a slow slide out motor, and pulled the belly down to get at the motor to check electrical connections. Checked voltage at ...
You checked the slide fuse contact and got low voltage? How did the other connections test? The main battery positive and negative lugs at the converter?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
