I have a 2006 Forest River Sandpiper that I've owned from New. Dealing with a slow slide out motor, and pulled the belly down to get at the motor to check electrical connections. Checked voltage at ...
My slides have separate fuses in their own fuse holders close to battery as they are directly wired to battery (do not go thru DC Dist Fuse Panel)
Everytime I have had a slide running slow it has been due to bad connection at it's fuse holder
Some slides have DC circuit breakers vs fuses. Fuses and CBs are typically real close to battery either on wall or floor (mine are inside a cover box on floor)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
