oldtrojan66's avatar
oldtrojan66
DC voltage off
I have an 07 Jayco 36RLTS in which (I think) everything works. Except the far stern 12 volt lights. The ceiling lights and the undercabinet halogen puck lights. The only place I can get voltage by meter is the puck lighting. There it reads 11.8 with the puck disconnected. I get a 00.0 reading from the wall switch for the ceiling lights to a known good ground. I also get 00.0 from the ceiling fixture regardless of the position of the wall switch. I'm not sure where I would pull wires if I knew what to pull. Anyone else ever have this kind of thing?
All other ceiling lights and pucks are normal. Voltage reading is 13.1 and I am plugged I to shore power. No other 12 volt issues that I know of. Thanks in advance....
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Matt_Colie wrote:
    O\Use a test light and not a meter.
    Matt
    AMEN to that.... I have both (Multiple test lights and multiple meters)
    I have found problems quickly and easily with the test lamp which the meter said did not exist.
    WHY
    Imagine this following circuit
    Battery----Wire---Bad spot with 1,000 ohms resistance------Meter
    The meter is a 10,000 ohms per volt set on the 20 volt range so the input impedeance of the meter is 200,000 ohms
    The voltage the meter sees is thus 13.6* 199,000/200,000 (Very nearly 13.6,in fact the difference is less than the error range of the meter)
    With a test lamp.. The lamp can be 1-2 Ohms Now the voltage it sees is 13.6 * 2/1002 or a tiny fraction of a volt.. IT will not even glow
    THIS happned to me.. Twice so far... In this rig Once was a bad connector, once a bad wire. (not counting battery connection issues)
    I do some work at a thift store... Happened to the owner's wife Wed. (Battery connection) She has new cables now.
    The test light shows NO LIGHT where the meter shows NORMAL.
  • One (just one of many) of the things that I think is un-smart of RVIA is that they didn't look at either USCG or boat builders guidelines. As a result, RVs have a great deal more electrical trouble than they should. In the time before the current depression, I did a great deal of boat work, but I also got roped (well, they did pay me) into tracking down electrical issues in RVs. Loose connections is a chronic issue. That is exactly what you are describing.
    Check both sides of every switch and connection.
    When you can't tell where a circuit runs, get a tracer. (A tracer is a gadget you put on the line and it uses a radio signal that an included receiver picks up.) It may not be cheap (the cheap ones still do work), but think of what it will cost to have someone like me find the problem.
    There is no quick answer, it takes the doing to fix these.
    Matt
  • RoyB's avatar
    RoyB
    Explorer II
    Being the unit is a JAYCO you can contact them along with the VIN number and request a wiring diagram. That may help track down a possible bad junction point somewhere behind your walls that may lead to fixing your problem...
  • Most likely problem is a loose connection behind one of the fixtures
    The last working fixture on the circuit is the place too start looking
    Of course you might have two.lighting circuits, with one being totally out, in that case start at the non working fixture closest too the power center a k a 12v fuses
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
