Cdash's avatar
Cdash
DC Voltage issues
I have a 2006 Forest River Sandpiper that I've owned from New. Dealing with a slow slide out motor, and pulled the belly down to get at the motor to check electrical connections. Checked voltage at battery while operating slide and the battery went from 13.47 down to 13.2. Seemed pretty reasonable to me, so moved onto the other end.
After redoing the connections at the motor (found some corrosion in the electric nuts) checked the voltage at the motor connections and was seeing voltage drops down to 8 volts with the slide running. Knowing that this is an issue, I checked voltages in the fuse box by touching the ground lug and the power lugs under the automotive style fuses. I was seeing numbers in the range of 10 to 11 volts. I expected that these would read the same as the battery. I have two heavy cables connecting to the fuse board, one red (from battery, I'm assuming) and a white one (from shore power/converter, I assume) The white was reading 13.47, I don't recall what the red one read. Plan to do more checking tomorrow, maybe pull the slide switch and check voltage there as well as see if there are any other connections in that line.
This has me a bit stumped. Anyone have any ideas on why I'm seeing voltage drops like this? Especially at the fuse panel?
Ideas?
  • Just had the same sort of slide problem and found similar numbers doing checks. It turned out to be the slide switch itself which has contacts inside it that were going bad. It seems this is a common problem. Replaced the switch and all is good. All the battery power passes through the switch on the way to the motor.
    In addition, the switch input neg wire came from a connection to the frame. This connection was corroded. Unknown whether that was a poor contact, but cleaned it all up anyway.
    We had the earlier version of the Lippert switch and the new one has different wire colours. Lippert website has the diagram on how to match up the wires going from old to new.
  • My slides have separate fuses in their own fuse holders close to battery as they are directly wired to battery (do not go thru DC Dist Fuse Panel)
    Everytime I have had a slide running slow it has been due to bad connection at it's fuse holder
    Some slides have DC circuit breakers vs fuses. Fuses and CBs are typically real close to battery either on wall or floor (mine are inside a cover box on floor)
  • You may be running through relays also. Mine are in the back of the cabinet above my converter. One for slide and one for landing gear
  • You checked the slide fuse contact and got low voltage? How did the other connections test? The main battery positive and negative lugs at the converter?
  • You are doing the right things. Keep following the wires, ground and hot wires, and you will find the problem.
  • I doubt the wire itself is causing the 2v to 5v drop. Keep poking around and I think you will find another bad connection. Check for auto-reset beakers in the line.
  • I would redo all connections and replace wire with a larger gauge. :)
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
