sealevel_ram
May 21, 2018Explorer
DrewE wrote:
One possible place to start checking--not the only possible culprit, of course--is the shutoff latching relay for the "salesman switch".
One way to verify is to see if the voltage at the battery, measured with a trustworthy multimeter, goes down along with the displayed voltages in the RV. If the display goes down but the battery stays pretty much level, the problem has to be between the two somewhere.
Is this the House ON/OFF switch by the entrance door?
Display voltage goes down, the battery voltage stays up. In other words, when the display shows low voltage, the batteries are still 12+.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
