JiminDenver's avatar
JiminDenver
Explorer II
Oct 18, 2014
De-rating the 230w
I hauled the 230w Schottpoly out to see if I could tone down the voltage by turning it or partially shading it.
I found that to get the Voc down to 32v by turning it, I had to turn it 90 degrees to the sun. A piece of card board 28 inches by 20 inches placed over the panel while lined up with the sun took it down from 35v to 32v. I would tell you the Isc at those times but trying to see what it was when it was still clear and cold out and popped the poor little HF meters fuse. :(
  • I'd be happy to do it to the Canadian solar 220w as long as it was reversible. I am assuming it would just be moving the wires around in the junction box. That's going to drop the Voc of that panel down to 17v or so in bright light. Will that be enough for bucking? Would it even convert the panel for use as a PWM system?
    On edit, neither easy or reversible. Too bad too because it accrued to me it could be a way to mate a cheap PWM controller to a cheap 24v panel. Halving the Voc would mean halving the working voltage too, right? That would be dropping below 15v for the 220w.
    How many cells 60? Have you looked at rewiring the cells to have half in parallel with the other half?
    Not sure how to best incorporate the bypass diodes. Looks like you clip the left middle connection and bring wire to the other end.
    Give Vmp of 15 volts.... might be a little low or might be perfect with PWM.
  • I went looking for Schottpoly panels and they are discontinued. The few I found were over $500 except for a scratch and dent at $251, and it had different specs than mine did.
    I would imaging any 230w poly panel will be close to the same for far less money.
  • Thanks for that test. I am surprised it took that big of a cell covering to get the Voc down, but at least the idea works.
    My 230w Hanwha panel has an Isc of 8.3a which it does in full sun if not 8.4 Voc rides around 34v of its 36.8Voc as soon as the sun gets on it, it warms up fast, which drops the Voc. I see solarblvd has a Hanwha 235 going for $160! Mine cost me $260 last year up here :(
    I still don't know if the Isc of a 24v panel like that has any meaning at all for what amps you get with the buck MPPT controller.
    I am suspecting the Isc has nothing to do with it, and it is all about the wattage at the controller output divided by the battery voltage.
    OTOH, the 12v panel gets Isc in full sun and you can use Isc as your "expected amps" with the usual PWM controller.
  • Mex
    I don't even know if SchottPolys are still around. I'd love to find two more in place of the three mono panels I have.
    I knew better than to test the Isc in those conditions. Normal conditions produce over 9a.
  • That'll Learn Ya ! :)
    That sounds like a great panel. Could you PM a where to buy link?
    I hear occasional squealing but so far no piggy bank. That is one crafty little dude.
