Boozecamp wrote:
MEXICOWANDERER wrote:
"Hello! Hello! Doctor! I am short of breath what could be the problem?"
Just enough description of symptoms to qualify ten thousand possible guesses.
Get volt meter in hand
Check battery voltage
On face of CONverter check battery voltage at positive and negative studs.
But you can check to see is CONverter breaker has tripped. Cycle it on and off few times then grab a hand held meter. When you post your battery and working converter voltage more will become known to the troubleshooters on this forum/.
Thanks! is the converter, typically located behind the removable wall in the basement? near the other utilities, (WH / Funance / Etc)
Mine is under the fuse panel which is below the oven.
And you could use a battery charger until you get it figured out and fixed.
