elle8's avatar
elle8
dead engine battery
can anyone tell me if its okay to jump my engine battery off my house batteries . is it that simple .
  • poncho62 wrote:
    Sure....They are both 12 volt.
    However, if your engine battery is dead, charging it from dead is quite hard on your charging system, always best to charge it with a trickle charger. I know if you are in a bind, no choice...but just saying
    X2 I agree.
    Since you have power from your house (shore power) why not connect a battery charger to your engine battery and recharge the battery that way? It is a whole lot safer, easier and won't potentially harm your charging system.
    Even my 2008 Winnbago and current have a switch to start it off the house batterie, I am sure you will find the switch on your dashboard
    Label on mine is battery boost
  • Sure....They are both 12 volt.
  • It will work unless the dead battery is shorted internally and then your asking for serious problems, like fried alt. or fire.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
