Mshaneweaver
Apr 13, 2014Explorer
Ok I messed with it today. There are three solenoids next to the battery, two have fuses on top and one looks like a standard ford starter solenoid. I'm certain the other two are really relays. Now that I have the new battery in there, the left relay "pops" when I hit the battery kill switch in the doorway. It's a temporary rocker switch though, I expected it to be an off/on switch. I could not find another kill switch in the battery bay. The ground to the chassis is good, put a meter on it and got good continuity. The red wire did not show continuity so I removed it and found that it was torn open exposing the copper wire. I figured I had it solved do got a replacement. Still no luck.
I can't find any fusable link unless it's inside the wire loom. I didn't crack the loom open. Where can I find a wiring schematic so I will know what the bundle of colored wires in the loom are for? Each of them go to a post on one of the solenoids.
I cleaned all the connections.
Any other ideas?
Thanks for all the help guys.
Any other ideas?
