DouglasC's avatar
DouglasC
Dead Onan 4000 generator
Went to fire up my Onan 4000 generator for the 1st time this year. Held the Start/Prime switch down on Prime and the light came on and flashed like usual. After about 5 seconds I released the switch as usual and pushed the Start side of the switch. Nothing happened - - totally dead. Tried the Prime side of switch again - - nothing happened. Last time this happened (generator dead) 7 years ago the cause was a faulty circuit board that needed to be replaced.
Anything else I should be checking before I order a new circuit board?
  • Apparently I do have 12 VDC at the generator because the light came on when I 1st went to Prime the generator. But I will definitely check to make sure that there is 12VDC at the generator before I order a new circuit board.
    I just reconnected all the battery cables to the coach batteries before attempting to start the generator so the connections are all clean.
  • I had the same problem with my onan 6500. I cleaned the battery cable connection at the battery and all was good. What threw me off is all the coach lights worked but the gen was dead.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
