brisath's avatar
brisath
Dead radio, levelling jacks, keypad lock
My 2015 Jayco Melbourne class C isn't getting any power to the radio, auto leveling jacks, and keypad lock but all other power seems to work and it drives fine. If it is fuse related please help with locating the right fuse. Same with locating isolator or solenoid that may be the cause. I recently was messing with and lubricating a stuck contact rod on the side bottom of the door, if that helps.
  • You find the coach battery. In that area, you will see the Battery disconnect solenoid. Jayco, installs various in line fuses to that battery cable connections on the solenoid for the Radio and such. Never noticed that they fused the jack system there, but since they are also inop, there is a problem there also. Fixing the door strut would not have caused your problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,327 PostsLatest Activity: Oct 26, 2025
