PCronin68 wrote:
donn0128 wrote:
If the original decals are in decent shape, simply install the new ones directly over the old. Of course proper prep is important first.
Thats what I was thinking...much easier. Of course clean and prep first
DO NOT apply new decals over the old, when they fade the vinyl allows uv light through to break down the adhesive behind so you will eventually end up with ruined new decals. Remember the old saying "when it comes to finishing, 90% of the work is in the prep and you should completely remove the old worn out decals and adhesives and do it right the first time. Go buy a heat gun from harbour freight and some 3M™ Woodgrain and Stripe Adhesive Remover, a couple of cases of beer and some burgers then invite a few buddies over for a re-decaling party, you should be able to re-do your rig in an afternoon having one guy carefully taking off the vinyl with the heat gun then another removing the glue, after their done you should clearly see the outline of the old decal and using a spray bottle with soapy water working from the bottom up re-apply the decals and carefully squeeze out the air bubbles with a good quality plastic squeegee ( all these supplies should be at your local auto-body supply shop)take your time and have fun, your labour will be rewarded!
Red Green;
Remember, If it moves and it shouldn't, duck-tape,
if doesn't move and it should,WD40!!
