- phenrichsExplorerI would not use a chemical on my fiberglass TT. A friend of mine works for a vinyl graphics place that does vehicle wraps and they use heat and the wheel.
- Ron3rdExplorer IIII used a heat gun along with a plastic putty scraper when I removed mine. Be careful not to get things too hot. You'll need to remove the left over glue too. The glue can be as big of a PITA as the decals. I removed the glue with plain old gasoline on a rag on the suggestion of a member of this forum and it worked great.
This was on an aluminum sided trailer. - Dick_BExplorerPrevious discussion. Search this Forum for `decals' then search the results for `3m'
- 96Bounder30EExplorer IIMoved from DIY
- harold1946ExplorerA 3M eraser wheel works great. Some use a heat gun and peel it off.
- tanman32225ExplorerUse a heat gun.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
