MEXICOWANDERER's avatar
Dec 26, 2017
Decent Buy On A Marine Grade Cigarette Lighter SOCKET
https://www.parts-express.com/marine-grade-cigarette-lighter-socket-12-vdc--265-274
This 12 volt receptacle is manufactured from corrosion resistant marine grade materials. It features an interconnecting system that securely locks the plugs into the locking receptacle resulting in a positive and moisture proof connection.
In Stock
List Price$10.99
Regular Price$6.97
You Save28%
Lifetime Tech SupportFREE
Sale Price
$5.00
Buy 100-499 $4.92
"My rig did not come with a cigarette lighter in the bedroom...yadda"
  • I wish we could move away from the cigarette lighter connector, it's such a terrible connector.
    It works fine for holding a small accessory, like an actual cigarette lighter plug. As soon as you add a few USB cables, or worse, 18-16ga wire going to a small inverter, the poor lighter socket just can't hold on.
    I don't see more expensive sockets working much better, how can they? It's just a metal barrel and a metal button at the end. How do you make that work better? I guess tighter tolerance on the diameter of the barrel, heavier material that doesn't deform under stress of a connection?
    Higher quality plugs on the other hand, they seem worth it, but seldom used in mass manufactured devices. Rarely is more than one spring contact employed to hold plug into receptacle, with cords hanging off the face, every bump and jostle walks that connection a little more out of the socket, away from the button supplying the +12v buffet.
  • marinco also makes a very good 12V receptical and plug if needed. way better than the cheap ones.
