pianotuna
Jun 26, 2020Nomad III
I had a 2500 watt Cobra MSW that was rated to run motors. I did sometimes use it on my roof air conditioner. It was $199 in 2009. I did use it at -20 C.
https://www.amazon.com/Cobra-CPI490-Compact-Power-Inverter/dp/B00S9S8NA4/ref=sr_1_32?crid=390AZDCJ7IRLK&dchild=1&keywords=msw%2Binverter&qid=1593236950&refinements=p_n_condition-type%3A6461716011&rnid=6461714011&sprefix=msw%2Binverter%2Caps%2C503&sr=8-32&th=1
owner's manual: https://www.manualslib.com/manual/932468/Cobra-Cpi2590.htmlContinuous output power (1 hour) . . . . . . . . . . . 2500W
Surge rating (0.1 second) . . . . . . . . . . . . . . . . . . 5000W
Peak efficiency (12V – 1/2 load) . . . . . . . . . . . . . > 88%
Installation
Efficiency (full load, 12V) . . . . . . . . . . . . . . . . . . . > 83%
Secondary Icons
No load current draw . . . . . . . . . . . . . . . . < 0.6A (12.6V)
Output waveform (resistive load) . . . Modified sine wave
Output frequency . . . . . . . . . . . . . . . . . . . . 58HZ – 62HZ
Output voltage . . . . . . . . . . . . . . . . . . . . . . 109V – 120V
Notice
Caution
USB output . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5V
Input voltage . . . . . . . . . . . . . . . . . 10.4VDC – 14.4VDC
Alarm voltage (unload) . . . . . . . . . . . . . . .11.0V – 11.6V
Shutdown voltage (unload) . . . . . . . . . . . 10.0V – 10.6V
Operating temperature range . . . . . . . . . . . . . 0°C – 40°C
Storage temperature range . . . . . . . . . . . . -40°C – 85°C
Protection . . . . . . . . . Overload, short-circuit, overtemp,
reverse polarity, under/over voltage
2500 watt = $299.95
130 watt = $14.95
Installation
Secondary Icons
Notice
Caution
2500 watt = $299.95
130 watt = $14.95
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
