SoundGuy
Mar 04, 2017Explorer
bgradert wrote:
I half tempted to order one from Amazon, assemble it, run the generator in it for a couple of minutes to see how it does.
SoundGuy wrote:
If you really want to control all the racket, which is particularly difficult with an open frame genset, you're going to have to spend some $$$, the most important expenditure being noise control barrier material such as this from West Marine.
Bumpyroad wrote:
I was wondering when somebody would recommend adding insulating material to the sides of the box.
This West Marine noise control barrier I linked to is far more than "insulating material" ...
"This flexible composite combines the sound-absorbing properties of open-cell polyurethane foam and the noise barrier capabilities of high-density PVC vinyl sheeting. The 3/32" flexible vinyl sheet is fused between two layers of foam an exterior ("decoupler") layer and an interior ("absorber") layer. The exterior layer is then covered with a thin film (2.5 mil) of mylar, reinforced with elastomer-coated fiberglass, for surface heat protection and enhanced sound absorption.
The overall effect is a dramatic noise reduction when compared with single-layer foam barriers."
Certainly, instead of a generator box one could line the cargo compartment of a truck with this sheeting but it sure would be costly, especially if the compartment had a lid like my Avalanche - that's a lot of square feet to fully cover and one would still need to provide an effective means of intaking cool fresh air and venting out hot cooling air & hot exhaust gas, just as I did with my own design.
