Sam_Spade
May 01, 2019Explorer
pnichols wrote:
Using my seven step K.I.S.S. method above ... have I been lucking-out all these years?
I have found as I get older, I tend to make more stupid mistakes than I did 40 years ago. It probably will catch up with you eventually too.
It is NOT a good idea to make any "jump" connections while the "donor" vehicle is running. If you DO make a bonehead mistake with the connections and the vehicle is running, you can fry the charging system and maybe other things along with it. If the vehicle is NOT running, all you will do is weld a spot on end of your cables....probably.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
