Homeless_by_Cho
May 01, 2019Explorer
pianotuna wrote:
Hi LeRoy,
Part of the excellent results may be due to the solar charge controller, especially if it is temperature compensated.
What make and model is it?Homeless by Choice wrote:
I mainly boondock with 250 watts of solar and two 105 amp hour AGM batteries. I get about seven years of service out of my batteries. I use AGM because it means no checking or adding water and the terminals are always corrosion free. My batteries are around 80% full charge each morning and they are generally 98-99% full charge each afternoon. Beyond that I can’t tell you anymore. I don’t ever recall them below 70% full charge.
Again, I am not criticizing anyone for their comments or advice but it is not understandable and therefore not usable for me.
Thank you,
LeRoy
pianotuna,
Sorry it took me so long to reply. Something came up that I needed to attend to.
My solar charger is Blue Sky Energy Solar Boost 3000i.
Thank you for your input. You have assured me that I am probably doing pretty good and I will continue that way.
Again Thank You,
LeRoy
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
