MEXICOWANDERER
May 05, 2019Explorer
A standard starter motor coupled to an engine will draw a battery down to 10.9 - 11.4 volts. About 4 - 5 times the amperage of a lawnmower starter coupled to nothing.
An RV starter armature coupled to nothing like the lawnmower armature in the video draws a fraction of what an armature does in real life.
He could have jammed a piece of wood into the starter drive gear to simulate a more realistic test.
Lock rotor's duration 1-2 seconds would have blown his numbers right out the window :) Touching the input lead would have yielded 90 - 125 volts not 25.
But the video shows there is a difference. Better than nothing. Heavy electric winches are worse yet. A battery does absorb some of the transients but less than 25% of the total.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
