atp20
Apr 28, 2019Explorer
Deep Cycle Battery Charging From Alternator
Hello,
May I ask for advice regarding charging deep cycle batteries from the alternator? I have read older threads, and understand opinions vary.
The previous two 100Ah deep cycle AGM coach batteries each failed in well under two years of intermittent use in my 2003 Sprinter Class B.
Would non-AGM deep cycle batteries last longer? AGMs have been said to be sensitive to overcharging. Any battery recommendations? Maintenance-free would be preferred because of awkward battery access.
Do I need to look into some sort of smart charger, alternator-to-battery charger, or inverter/charger setup? I'd like to keep things simple.
Would installing a second coach battery affect the situation?
The RV is used as a daily driver and for long distance trips, boondocking mostly. When traveling, the principal load consists of two refrigerators, drawing 2.5A each when active, plus a high power blender that draws about 95A (12v) through a 2kw inverter for two minutes a day. The coach battery is located under the rear floor, about 20' from the alternator. Not sure of the connecting wire size, which runs through an isolator and 50A breaker. The 120A(?) alternator charges at 14.4 volts when the battery is full.
Thank you. Any advice would be appreciated.
Jerry S
2003 Freightliner Sprinter Class B
S Florida
Jerry S
S Florida
