RJsfishin
Oct 26, 2012Explorer
Your power useage is not out of line at all.
If your converter only charges 5 amps, JUNK IT !
IOTA and charge wizard are not compatable.
4 6v golf batteries in a small 5'er is rediculous !
2 6 or 12v deep cycle batts will do you just fine, but you will need a 35-45 3 stage converter, and a little generator running 1-2 hrs a day, depending on your needs. But if you run that forced air heater, along w/ the other needs, figure on charging 2 hrs a day.....w/ a good 3 stage converter/charger.
