SDM's avatar
SDM
Def fluid
Have a 2011 Duramax. Have had a sensor problem. Dealer says the def from Walmart is giving some problems. Any thoughts.
  • Have used Super Tech DEF from walmart for the last three years 38K miles with no problems. I fill it up when I'm going to pull the 5er more than 3000 miles. Other than that I add a gallon at a time when it gets low keeping it as fresh as I can.
  • I agree that DEF is universal. But I have run into DEF which has long passed its expiration date. And the clerk had no idea that there is an expiration date.
    so I would advise that it is ok to buy DEF from Walmart as long as the expiration date has not come and gone.
  • Its the universal answer from the dlr. I had a 2011 GMC and the tank had to be replaced at 600 mi and again at around 75k mi. As well as a sensor a couple of times. It has nothing to do with the def you are using.
  • Have been buying Walmart Peak Blue DEF since I bought the 2012 F350 new. Never a Problem. Same brand that is sold at local auto parts stores.
  • In 40 thousand miles I have only used Peak Blue DEF in 2.5 gal boxes. All but one from WM. When it get to 1/2 on the gauge I drop by a WM and put in a box, and let them recycle the box.
    I always check the date code. Here is a sample of how it works.
    This is from a Dec 6th 2016 post on another forum.
    The code on the box is "12170412431 A"
    Doesn't look any different other then the "A" at the end
    12 = where made
    17= year made plus one
    041 = days remaining in the year that is was made
    2431 = Actual Batch code
    DEF made today by Peak would have
    xx19284yyyy code.
    That is, it was made 284 days before Jan 1st 2019.
    Chris
  • Hogwash, DEF is 35% Urea solution. It's the same no matter where you get it.
    BK
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
