Mayor30Explorer IISep 16, 2023DEF fluidIs all DEF fluid the same? I usually buy the Blue DEF but it's now about $20. Our local hardware store has the Blue DEF and another one that is $12.99. I did buy the Blue DEF but just wondered if the ...Show More
Grit_dogTrailblazerOct 02, 2023Bad def at the pump is about as likely as bad fuel. If one gets bad fuel, do you start buying fuel pre packaged in sealed containers?Same difference.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
