Mayor30
Sep 16, 2023Explorer II
DEF fluid
Is all DEF fluid the same? I usually buy the Blue DEF but it's now about $20. Our local hardware store has the Blue DEF and another one that is $12.99. I did buy the Blue DEF but just wondered if the ...
Grit dog wrote:
Bad def at the pump is about as likely as bad fuel.
If one gets bad fuel, do you start buying fuel pre packaged in sealed containers?
Same difference.
