Peg_Leg
Jan 02, 2014Explorer
I also had the 2 AM wake up call caused by low voltage. Before I found out about the low voltage feature I had soapy water all over the under side checking for leaks. I now have a volt meter directly above the detector and added a on/off switch to the circuit.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
