darsben1 wrote:
Keyteg1
How long ago did you do this? I am thinking about the longevity of the repair
I did the first repair about 3 years ago and more last spring.
Bare in mind none of those glues are water-resistant so they will hold as long as there is no water penetration.
On some areas like cord boxes, I used epoxy to laminate the old wood, what adds strength and makes it waterproof, but epoxy has its limits in application and doesn't work too well on vertical surfaces.
If you don't open the bubble and dry it, per my experience the trapped moisture will sit there for a year if no longer - still dry-rotting the wood.
