RLS7201
Aug 25, 2022Explorer II
The OEMs stopped installing CCI 7719 when CCI went out of business in 2008 (14 years ago). Not because of customer complaints.
I reversed engineered my CCI 7719 when it failed and made the necessary repair. The CCI solenoid coil is NOT 12 volt. It is a 9 volt coil. The valve is snapped open with 12 volts and maintained with 2 volts.
As already noted, if you have a propane leak while away from your RV, the system will shut off the propane, which would keep the water heater or refrigerator flame from starting a fire in case of a leak. I consider that added safety.
Richard
Richard
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
