dougrainer
Aug 26, 2022Nomad
RLS7201 wrote:
The OEMs stopped installing CCI 7719 when CCI went out of business in 2008 (14 years ago). Not because of customer complaints.
I reversed engineered my CCI 7719 when it failed and made the necessary repair. The CCI solenoid coil is NOT 12 volt. It is a 9 volt coil. The valve is snapped open with 12 volts and maintained with 2 volts.
As already noted, if you have a propane leak while away from your RV, the system will shut off the propane, which would keep the water heater or refrigerator flame from starting a fire in case of a leak. I consider that added safety.
Richard
They went out of business in 2008?. BUT, OEM's (the majority that did install) stopped in the late 90's. Customer complaints? I have 43 years as a RV tech(mainly motorized) 1979 to current. WHO would be better to state customer complaints? YOU or ME? I had to listen to people upset that their LP system shut down and caused problems with refers and all LP appliances. AS I stated, SHOW evidence of the supposed added safety with such a system. YES, such a system would be a nice feature, but due to the system unreliability, they were discontinued. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
