dougrainer
Jun 18, 2017Nomad
You did not state after you returned, is it working on LP now or it does NOT work on 120 at all? If it does not work on 120 and the wall receptacle is hot(has 120 power) then the odds are either the 120 element fuse is blown and/or the 120 element is defective. On Dometic refers, on AUTO, there is no indication when the 120 has failed other than the refer then runs on LP. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
