pianotuna
Aug 13, 2016Nomad III
Hi doug,
I cut and pasted it from the Full Time forum on winter camping. So it may well be that it is not standard equipment. i.e. not from my personal research or knowledge.
The Dometic quote is from an email that they sent to me.
I use the light bulb method on a thermocube myself. I laid in a supply of 60 watt bulbs as they are getting to be "hard to find".
dougrainer wrote:
Where did you get that Norcold installs as Standard? I work on them all the time and have NEVER seen that kit on any Norcold. That kit does the same thing that RV'ers have done for years in sub 32 degree weather----using a 40 or 60 watt light bulb to gently heat the back coil area. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
