3_tons
Jun 28, 2014Explorer III
On another note, it is possible that if you seldom use the RV that over a period of time, getting a false % SOC reading on your metering...This 'may' happen after a prolonged period of inactivity (RV non-use) where a small amount parasitical losses (say, rv circuit boards) overtime occur...Over a period of time, these slight losses can produce an unwanted (stray) accumulation of magnetic flux lines across the metering shunt (inserted into batt Neg Cable) thus a resulting phantom SOC% reading. The remedy for Xantrex LinkLite metering (not sure about Trimetric...) is to do a manual synchronization (basically a reset - a return to 100% SOC) after confirming battery is fully charged.
3 tons
3 tons
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
