- pianotunaNomad IIINot the question I asked. I have no interest in either PI or SG products.
tjfogelberg wrote:
We use portable surge guard. Simply and easy. It has a loop you could use to lock it to the power pole. When I buy a new RV, I will have one installed inside the power center. - pianotunaNomad IIINo, I only want surge protection. I check before I plug in.
STBRetired wrote:
You really want more than just surge protection. Look into an EMS system which will protect you from under/over voltage, open ground, open neutral, reversed polarity. they are available as built-in or portable units. Progressive Industries or SurgeGuard. - STBRetiredExplorerYou really want more than just surge protection. Look into an EMS system which will protect you from under/over voltage, open ground, open neutral, reversed polarity. they are available as built-in or portable units. Progressive Industries or SurgeGuard.
- 2oldmanExplorer IILooks like a Mex question. Google shows schematics for such a device.
- tjfogelbergExplorerWe use portable surge guard. Simply and easy. It has a loop you could use to lock it to the power pole. When I buy a new RV, I will have one installed inside the power center.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
