Gdetrailer
Aug 01, 2022Explorer III
I should also mention, someone could have also mixed up which side the backing plates went to..
Backing plates should not be interchanged between left side and right side..
One is marked Left and one is marked Right.
When you buy them you have to specify left or right if buying one, but always best to change as a pair (left and right) on the same axle to make sure the brakes work evenly between left and right..
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
