JimDandyAZ
Sep 02, 2019Explorer
dougrainer wrote:
This is a common problem on Ford Class A chassis going back over 20 years. The ONLY sure fix is to install a 12 volt vacuum pump and plug the vacuum line from the engine. You will have people tell you to test this and test that and add another accumulator, and check all the vacuum lines and motors on the dash evap system. The plain fact is, the aftermarket Dash AC systems on Ford Class A's have inherent vacuum leaks and cannot overcome the engine going to zero vacuum on full acceleration or climbing hills. You can do a search for this problem on this forum and see all the silly things people are told to do, when the plain fact is, you need the 12 volt pump. I speak from over 38 years and still working on Motorhome Dash systems and YES, I have installed a few of the 12 volt pumps, even years ago when the Coach Maker paid for the pump installation when the RV's were under warranty. Doug
The truth was in the middle. I found a vac leak with a pump tester. And Doug Rainer was right .. the F53 dash is inherently leaky. Installed the vacuum pump Doug cites. Bought the wiring harness while only using the black and green. Tied power to an ignition- on piggyback fuse. Unit shuts off when vacuum is correct. Does not run when ignition is off due to choice of where to tap 15 amp fuse.
***Link Removed***
