Mike_Schriber's avatar
Dec 01, 2018
Diagnosing a HVAC vacuum issue on a Ford F53
The AC/heat is switching to the defroster under higher RPM conditions on my 2006 F53 chassis Damon. It actually seems to be doing it now under low throttle steady state conditions as well. Obviously a vacuum issue but I'm not finding any obvious leaks.
The leads me to focus on the vacuum accumulator but I'm not sure how to test it. I can't even figure out how to remove the lines going in and out and I don't want to break anything fumbling around. Any suggestions?
Thanks!
Mike
  • Sounds a lot like a chaffed or cracked vacuum hose, may not hear the leak depending on the location of the leak.
    Most likely will need to start inspecting all of the vacuum hoses, not sure what engine you have but there are a few well known issues with vacuum lines and hoses on the modular engines which have a history of chaffing and or cracking from heat in the engine bay..
  • Actually... I just unplugged the hose from the accumulator where it connects to the dash controls. The baffle for the defroster immediately dropped and the line was hissing. The engine has been off for a half hour so that tells me the accumulator is fine. It would also suggest there's no leak elsewhere in the system which makes no sense.
    Any thoughts?
    It could be between the manifold and the accumulator but as near as I can tell that line is fine. The other vacuum line from the manifold goes to a device with an electrical connector on the driver's side valve cover. I'm guessing this is a valve related to the PCV system and if it was bad I guess it could deprive the whole system of vacuum but I don't want to go down that road without more information.
    Thanks (again)!
    Mike
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
