jodeb720's avatar
jodeb720
Dicor Water Based EPDM Adhesive DryTime
As directed, I did my roof patch this weekend. I put a piece of Luan over the area above the bedroom in the 5er, nailed that to trusses and used some construction adhesive to ensure it's not going anywhere.
Then I broke into the Dicor water based adhesive - which has no instructions on how to use the stuff, anywhere. not online, not anywhere.
I applied it to the Luan first - and the put a thin coat on the bottom of the epdm and put it down - making sure there are no creases or bubbles.
So far so good.
I put that down this morning (sunday). Now for reference, I'm in Denver, and the humidity is low, and it was in the low 80's today.
When I went to check on it this afternoon, it was still tacky and you can lift the EPDM up - which normally isn't a good thing, but since there's no instruction, I just don't know.
Does anybody know:
1. How long it takes for it to dry?
2. When it's dry should you be able to peel up the EPDM from the RV Roof?
3. What is the recommended application - slop it on, roll it out or just a thin coat?
I've worked with other things (e.g. Contact Cement, Silicone, or other glues but this one I'm perplexed with.
Thanks in advance!
Josh
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
