JiminDenver
Apr 28, 2015Explorer II
C.B. wrote:JiminDenver wrote:
Sounds like the Honda Handi they came out with a few years back. Louder and more expensive that the EU3000is and pretty much identical to the Champion 3100i that sells for $799.
The Honda Handi EU3000i weight is 78 lbs. IT's dB at rated load is 65.
The Honda EU3000is which is 134 lbs. It's dB at rated load is 58.
You cannot compare the Champion to the Honda. Champion dB readings are taken at 23 feet. Honda dB ratings are taken at 9 feet.
You can go on Honda's web site and order a brochure. On page 16 at the bottom of the page you'll find the below statement "Noise levels at rated load to reflect noise level possible, measured at 9 feet(3 meters) from the control panel side of the generator.
C.B.
The Champion 3100i weighs the same, looks the same and is rated for the same db at the same distance. Perhaps you are thinking of the Champion 3500/4000 that isn't an inverter model, weighs more and is 3 db louder than the handi or the 3100i, will run more and is $300.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
