Sabluka wrote:
Looked in MagnaTech Control Panel. The 10-amp breaker was tripped.
The fan for the AC unit is working well. So i was wrong abt the htg/cooling controls just handling the furnace blower.
Also...here's a related question. Even with the heating furnace sys off and the AC not turned on etc....the furnace fan will just come on for a few minutes and then stop. Does it consistently but doesn't stay on long.
Now since the water compartments are heated, I thght it was somehow knowing to circulate air there.
But maybe it's a safety feature to insure venting of gases?
Havent called Winnebago yet to ask them
RR
NO RV has a system to circulate air in the basement at odd times or even as a safety feature. There should be NO gases at anytime in the basement. The furnace fan should never do what you state it does. From your description, it seems like the Hi limit switch is activating, but I have never seen one do that. Depending on the brand/model furnace, the fan relay may be acting up. Does the furnace ever light the burner when it does this? Are you positive it is NOT the Converter cooling fan coming on and off? Doug
