kmb1966's avatar
kmb1966
Did I ruin my brand new tires with a pressure washer???
I recently had 6 new tires mounted on my motorhome. The shop had alot of white ash/dust all over and it got all over my new tires, so I came home and tried to wash it off. I tried some soap and it didn't clean it off very well, so without 'thinking', I grabbed my Husky electric 1500 psi pressure washer, and washed the tires. Now, I didn't put it on the stream/bead or anything like that, but I did have it on the fan spray mode, and admittedly sprayed it around and around to get this dirt/ash off of the new tires. Now, I'm hearing that wasn't such a great idea. Now I'm concerned if I somehow ruined my tires. Does anyone use a small electric pressure washer? Did I ruin these new tires?
  • 4x4ord's avatar
    4x4ord
    Explorer III
    If you hurt your tires with a pressure washer the tires were shot to begin with.
  • I've cleaned the wheels from one of my cars with a pressure washer for years. Some of the stream hits the tire. Never a hint of a problem from it.
  • So long as you were not using the cutting or chiseling tips, 1,500 psi on fan isn't going to cause any damage if it was in motion.
  • I wouldn't worry about it. Many drive through cars washes hit the tires with a pressure washer before you go through. 1500 psi is a rather low pressure all things considered.
    If you did not use chemicals that are detrimental to the tires, you should be good to go.
    No, I just used the water hose connected to the electric pressure washer. I used plain soap and water
  • I recently had 6 new tires mounted on my motorhome. The shop had alot of white ash/dust all over and it got all over my new tires, so I came home and tried to wash it off. I tried some soap and it didn't clean it off very well, so without 'thinking', I grabbed my Husky electric 1500 psi pressure washer, and washed the tires. Now, I didn't put it on the stream/bead or anything like that, but I did have it on the fan spray mode, and admittedly sprayed it around and around to get this dirt/ash off of the new tires. Now, I'm hearing that wasn't such a great idea. Now I'm concerned if I somehow ruined my tires. Does anyone use a small electric pressure washer? Did I ruin these new tires?
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 24, 2025
