I have a 2006 beaver Monterey The felling up of diesel is terrible it takes forever it takes fuel vary vary slow does anyone know why this is and can there be anything done about it
Most likely suspect is a poorly routed VENT hose. If there is a drip loop in it/sag in it fuel can cause the fill to back up.
So, crawl under and verify that the small diameter vent hose goes only up hill from tank to vent port on the filler neck. If that hose was cut 4" too long (so it has a sag), it will add 10 minutes to your fill time!
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
